1978 28 mirage part out >
Old 04-02-2017 | 09:15 AM
Sick Stinger's Avatar
Brotherhood #1
Default 1978 28 mirage part out
1978 mirage part out. Has a soft transoms other then that it's solid.
454 420 motors low hour from what owner said 75 range. 3500 each 4500 with exhaust
8000 for both with exhaust
72C green tag trans BW 700 each 1200 for both
25P mirage props 350
Hynautic full hydraulic steering 2000 TRS or I have a bravo plate also
TRS drive 2500 for the pair
Transoms for parts 700 both
Indicator set up 450
Tabs 1000 compete
Trailer BOS 2500
Bolster seats 400
Batt boxes 75 both
Mufflers 200 a set
Bellhousing a 100 each have a stack of them
Torque plates 100 have a stack
Controls 200
Anything else please ask.
[ATTACH=CONFIG]566042[/ATTACH][ATTACH=CONFIG]566043[/ATTACH][ATTACH=CONFIG]566044[/ATTACH][ATTACH=CONFIG]566045[/ATTACH][ATTACH=CONFIG]566046[/ATTACH]
Attached Thumbnails 1978 28 mirage part out-image.jpg   1978 28 mirage part out-image.jpg   1978 28 mirage part out-image.jpeg
Sick Stinger is offline
Old 04-02-2017 | 01:05 PM
how much for the map/chart box?
Thriller62 is offline
Old 04-02-2017 | 05:16 PM
Brotherhood #1
Let me see how easy it is to remove , hate to break it.
Old 04-03-2017 | 03:55 PM
what condition is the exhaust in
seaman is offline
Old 04-03-2017 | 04:50 PM
ROB FREEMAN's Avatar
controlles n cables ?
ROB FREEMAN is offline
Old 04-03-2017 | 07:11 PM
Brotherhood #1
Fresh water since new I'm told. Should be all in nice shape.
Controls and cables 225 shipped sound fare?
Old 04-04-2017 | 06:03 PM
Did you get a chance to check out the chart box? Do you have any pictures of the cabin teakwood? My boat is missing a lot of it.
Old 04-04-2017 | 07:29 PM
Brotherhood #1
I will see what I can do with pics. The interior is compete and in nice shape.
Old 04-04-2017 | 09:28 PM
how old is the exhaust and can you pressure test them. also will you separate the drives.
seaman is offline
Old 04-04-2017 | 09:30 PM
Brotherhood #1
I have a couple drives here if you need TRS
I can pressure check age I do not know.
