What is wrong >
What is wrong
What is wrong
Old 04-03-2017 | 11:55 AM
Default What is wrong
Ok so we just repowered my boat. 94 sunsation dominator. Bravo 26. 6 1/2 deep drives. Last year we ran 489 9.6:1 comp 284hr cam 230/236 .547/.547 lift l29 heads with stamped rockers air gap intake and quick fuel 750 carb. Pertronix marine distributors. Max rpm was 5100 at 72mph with roughly 400hp @28 max timing
This year we have 489 8.2:1 comp crane 741 enginequest 320 heads, crane gold rockers, victor jr intake, quick fuel 750, kn filters with stub stacks, pertronix distributors. Max rpm 5100 at 72 mph. Timing at 34 currently afr 12.5 Wth is going on. We should have 120-150 more hp per side. Im all ears
mggdoors is offline
Old 04-03-2017 | 12:03 PM
I had to read that twice looking for which blower. Why 8.2:1?
TxHawk is offline
Old 04-03-2017 | 12:17 PM
We are set up to run blowers in the future. It is a hard runner, much quicker than previous year build. My peak should be at 55-5600. Do I need to bump timing up to 38-40?
Originally Posted by TxHawk
I had the read that twice looking for which blower. Why 8.2:1?
mggdoors is offline
Old 04-03-2017 | 12:50 PM
The first set up was doing pretty well considering the use of truck heads . Its hard to make big power even at 489 cubes , with 8 to 1 compression ratio. But for mow you should def be safe with 87 octane until the blowers go on
airjunky is offline
Old 04-03-2017 | 01:02 PM
Dropped compression almost a point and a half and put in a bigger cam and went to a single plane.
picklenjim is offline
Old 04-03-2017 | 01:13 PM
Prob needs more carb.
Griff is offline
Old 04-03-2017 | 01:19 PM
Dropped compression is minor as it is only a 3% difference in power per point. Old heads flowed 255 at .600. Now we are at like 345. Also I took into account of compression when comparing to 525efi which is 8.75:1. Same cam. Way better heads. Weak carb. Im almost thinking carb and timing increase. Does the general rule of 1 degree advance equals 1 percent hp gain on bbc
mggdoors is offline
Old 04-03-2017 | 01:23 PM
How big griff
mggdoors is offline
Old 04-03-2017 | 01:55 PM
Knot 4 Me's Avatar
Got a buddy with 489's with Brodix BB-2 heads. Not sure on cam. Merlin intake. 850 Holley 4150's with the towers cut off. 35- 36 degrees timing. 89 octane. 5,200 - 5.300 RPM. Pushes a '96 303 SR-1 to 75 - 77 MPH. Way less efficient and heavier hull than your Dominator.
Knot 4 Me is offline
Old 04-03-2017 | 02:02 PM
How far can i lean on my timing with 8.2:1. I am running 87 now but am not afraid to run 91. Also im running comp lifters set at 3/4 preload. Could that be an issue
mggdoors is offline
