Why Are Inadequate Drives Acceptable On Boats? >
Old 04-20-2017 | 10:33 AM
Default Why Are Inadequate Drives Acceptable On Boats?
In particular, Bravos. They constantly break and need new gear sets as maintenance. In the car world a rear axle that breaks every few years would be completely unacceptable. This should be unacceptable on boats too.
thirdchildhood is offline
Old 04-20-2017 | 10:47 AM
BenPerfected is offline
Old 04-20-2017 | 10:56 AM
Because Mercury sells replacement parts.
phragle is offline
Old 04-20-2017 | 11:18 AM
Because you can get a pretty nice rear axle for a car for a couple grand compared to $20,000+ for ONE M6 drive
TorchLK is offline
Old 04-20-2017 | 11:38 AM
because just like boat engines, the drives/gears are under constant load = faster wear/tear. Both boat engines and drive-trains have shorter lifespans than their automotive counterparts.
In both auto and marine, the higher performance machines have more rigorous maintenance schedules - make sure you are comparing apples to apples.
sailtexas186548 is offline
Old 04-20-2017 | 11:44 AM
Because money
no further reason is needed
Nate5.0 is offline
Old 04-20-2017 | 11:47 AM
VP of the tickfaw200
Still wish you could get a TRS upper and bravo lower together. Nothing like the feel of transmissions when shifting.
caseyh is offline
Old 04-20-2017 | 11:50 AM
t500hps's Avatar
21 and 42 footers
How many rear axles are repeatedly bounced off the ground under acceleration AND overpowered for their rated use? Add a blower to a stock engine and run the car down a drag strip regularly.......then see if the manufacturer warranties the thing. Remember, Mercury DOES make drives that last, they just cost ALOT more up front.
I blew several XR's in my time. But each one was at 600+ hp and had an occasional launch off a set of tug boat wakes. Not Mercury's fault IMO.
t500hps is offline
Old 04-20-2017 | 11:57 AM
http://www.offshoreonly.com/forums/d...avo-lower.html
hogie roll is offline
Old 04-20-2017 | 03:35 PM
Well some of us Donzi 22 owners are eagerly watching this Arneson project. Not cheap but neither is replacing drives routinely: http://www.donzi.net/forums/showthre...2-with-Arneson
