another anchor post
The "custom" anchor than comes with my 35 Lightning doesn't work well. I found the identical anchor, not customized, and it turns out the customization was limited to cutting a few inches off of the stock (the metal dowel) on both sides. That prevents the anchor from flipping on to the fluke, but allows the anchor to fit in the anchor locker. My experience is i need 80-100 feet of scope to anchor in 3-4 feet of water. Chain doesn't seem to help much. I recently got my Overtons catalog and there's a couple of nice looking anchors that look like they would hold much better. One is a digger anchor #79634 and another is a Chene anchor (33823) Anyone have experience with these and any idea if they would at least fit into my anchor locker? I guess I could just get a non customized fluke that wouldn't fit in the bracket. What are other people using....other than the custom fluke style anchor?
I am using a Fortress, fits under the back seat, port side with the small access door open. FX11 I believe, light and easy for my wife to handle, hooks real well. I took my factory anchor in the bow and polished it and put it back, wasnt used much by the PO.
I recently bought a Fortress FX-11. I've cut it down and redrilled the holes to match the factory mount in the anchor locker. Not sure if it will work any better, but it is certainly lighter. My wife handles anchoring and storing, so I'm trying to make her job easier. If this rain ever stops, I'll report back on my findings with pics.
Buy a Box Anchor and keep it folded up under the back seat or in the cabin.
You will be surprised how well this anchor works.
No, it's not going to work with your anchor locker, BUT...
...you could keep 20' of line attached to the anchor, throw it from the cockpit, and then carry bitter end that has an eyelet on it, up to your bow and attach it to the rhode line you keep in your anchor locker for long term tie off.
You also won't need a rhode anything like you have needed in the past with the box anchor, AND it doesn't require a chain. The arm on the anchor does the work of a chain.
For sand or mud bottom the Danforth anchor is the one. Box anchor ?????https://youtu.be/gBB6TFSZepI.
The ONLY time my Box Anchor would not catch at all since I started using one in 2001 was on the bottom of a tidal/brackish creek that was FILLED with a 2-3' (feet) thick layer of hydrilla (seaweed) that you couldn't even walk on because it was the consistency of a giant sponge. Of SIGNIFICANT note: NO ONE'S anchors of any size or design would grab that day. NONE.
