Backfiring through intake >
Old 05-07-2017 | 07:37 PM
Hi folks. I need some help from someone who's a lot more experienced than I am.
I was de-winterizing the engines (2000 Mercruiser 8.2L (502CI)) MPI and the starboard engine is giving me a fit. It ran perfect until when I just tried to start it this week. When turning over, it will idle but the idle is erratic and it will backfire through the intake. I did a compression test (all were within spec), checked the spark plug wires a half dozen times, made sure the wires are routed right, installed new distributor cap, installed new ignition coil.... .but still backfiring through the intake. Plugs looked fine as well.
What should I do next? Could it be a bad / clogged up fuel injector?
Any help or suggestions would be greatly appreciated.
Blown284 is offline
Old 05-07-2017 | 07:49 PM
I'M NOT A MECHANIC
Could it be the timing? Bump the distributor and knock it out? Lord knows I did that by accident in a car I once owned - drove me crazy.
Just a thought
3pointstar
3pointstar is offline
Old 05-07-2017 | 07:53 PM
Originally Posted by 3pointstar
I'M NOT A MECHANIC
Just a thought
3pointstar
Haven't bumped the distributor. It's in the same place bolted in just the way it was when I put the boat away for the winter. I have to loosen up bolts to move it.
Blown284 is offline
Old 05-07-2017 | 08:02 PM
intake valve may have some rust build up,,it's not seating properly,just back firing thru to the intake.
sutphen 30 is offline
Old 05-07-2017 | 08:59 PM
Wouldn't the compression be low if it was a valve issue?
Blown284 is offline
Old 05-07-2017 | 09:14 PM
a bad injector would be a dead miss. no fuel to backfire with. yes, a bad intake valve, bad enough to blow back like that would show almost no compression. do both these engines turn the same way? or is this a shaft boat, not I/O? check plug wires again. it is always plug wires or some other spark going to wrong plug thing.
dereknkathy is offline
Old 05-07-2017 | 09:26 PM
Did you pull distributor to ck gear and shine down in and take a look at the cam gear. Also double ck ignition grounds. All grounds for that matter. Your symptoms sound almost like your dist is 180 off which I know isn't the case but. Ignition module?
getrdunn is offline
Old 05-08-2017 | 01:02 AM
It sounds like an ignition problem. Check all plug connections to ignition system for corrosion. Pick up module in distributor could be a possible cause as well.
You said you changed dist cap--what about the rotor???
Griff is offline
Old 05-09-2017 | 05:13 PM
Checked plugs and firing order several times. Did not replace the rotor because I really don't want to just throw parts at this.
Blown284 is offline
Old 05-09-2017 | 05:20 PM
Ya be careful those rotors are pricey. Lol. Should replace at time of cap as a rule of thumb. Kinda doubt it's the problem though. Isn't this fun.
getrdunn is offline
