525 crankshaft sensor
Old 05-15-2017 | 03:12 PM
Default 525 crankshaft sensor
I believe I need to replace the crankshaft sensor on my 525 motor. Does anyone know if there is a cross reference part number for GM?. Through Mercury, the part is $200 or so.
fastmcars is offline
Old 05-15-2017 | 04:12 PM
I don't think so, because it's on the timing cover and is part of the Merc. timing set but I'm not 100% certain of that.
HyFive578 is offline
Old 05-15-2017 | 04:18 PM
SB
If no one answers, pull the sensor and get the printed #'s off it, and we'll do some digging.
SB is offline
Old 05-15-2017 | 04:36 PM
SB
I think I found it:
AC Delco # 213-3208
(GM #12596851)
Delphi SS10125
This is how:
I found Quicksilver Camshaft Position Sensor #864297T01 was listed for the foloowing Mercruiser engines:
Applications
350 MAG MPI ALPHA/BRAVO/BRAVO EC
350 MAG MPI HORIZON ALPHA/BRAVO EC
350 MPI ALPHA
377 MAG MPI BRAVO/BRAVO EC
383 MAG STROKER
383 STROKER SCORPION BRAVO
5.0L MPI ALPHA/BRAVO/BRAVO EC
5.7L MPI HORIZON MIE
5.7L MPI MIE, MPI MIE EC
5.7L MPI TOWSPORT WITH GEN III
525 EFI
565 EFI
6.2L MPI HORIZON MIE
6.2L MPI MIE, MPI MIE EC
600 SCi
662 SCi
700 SCi
8.2L INBOARD (Base) EC, (H.O.) EC
8.2L Mag (Base Model), (H.O. Model)
8.2L Mag EC (Base Model), (H.O. Model)
And since I know the Merc 7.4's and 5.7's use the 7,4L and 5.7 GM factory crank sensor set up, they use the same one, I looked that up at ACDelco.com.
ACDelco Engine Crankshaft Position Sensor
Part Number: 213-3208
Product Notes:
All; MATING CONNECTOR w/LEAD USE PT2782
Astro(10)1996-2005
Blazer(11)1995-2005
C1500(11)1996-1999
C1500 Suburban(4)1996-1999
C2500(17)1996-2000
C2500 Suburban(8)1996-1999
C3500(13)1996-2000
C3500HD(5)1996-2000
Express 1500(26)1996-2007
Express 2500(26)1996-2005
Express 3500(14)1996-2002
K1500(11)1996-1999
K1500 Suburban(4)1996-1999
K2500(11)1996-2000
K2500 Suburban(8)1996-1999
K3500(10)1996-2000
1996 5.7L V8 VIN:R
1996 7.4L V8 VIN:J,N
1997 5.7L V8 VIN:R
1997 7.4L V8 VIN:J,N
1998 5.7L V8 VIN:R
1998 7.4L V8 VIN:J,N
1999 5.7L V8 VIN:R
1999 7.4L V8 VIN:J,N
2000 5.7L V8 VIN:R
2000 7.4L V8 VIN:J,N
And then pic's for further verification.
1st is Merc photo:
And then photos of AcDelco part:
And then the Delphi part:
SB is offline
Old 05-15-2017 | 04:39 PM
SB
Looks like Amazon, Summit Racing, and etc sell the AcDelco for about $55.00.
Here's the Amazon link:
ACDelco 213-3208 GM Original Equipment Engine Crankshaft Position Sensor
by ACDelco
Link: http://a.co/3hCRGpE
And the Delphi around $52.00
Delphi SS10125 Crankshaft Sensor
by Delphi
Link: http://a.co/0fw0h3E
SB is offline
Old 05-15-2017 | 04:45 PM
SB
Disclaimer: I am usually 95-98% correct when I find ACDelco parts for the Mercruiser Engine's when I do it this way.
So.........you need to make sure...which will be easily done when you buy this one and you pull your's and compare it side by side.
Hope this was vaild info and it works for you !
SB is offline
Old 05-15-2017 | 05:16 PM
That just goes to show you what that thick shiny black (blue) paint is worth cuz it triples the price of everything.
dereknkathy is offline
Old 05-15-2017 | 09:00 PM
Awesome, great job. I'll report once I've finished!!!
Old 05-16-2017 | 10:56 AM
Hey SB, looks like you know what you are talking about, so here goes. When my motor stopped, I looked at my vessel view, it said crank/cam sensor failure. I'm assuming it was the crank due to the way it just stopped and wouldn't start. My question is, can I read a code off the computer with just an automotive OBDII reader that may be more specific to either the cam or crank sensor?
Old 05-16-2017 | 01:15 PM
You need a Rinda scanner to read the codes. An OBD scanner will not work.
Griff is offline
