1993 fountain lighting fuse >
Old 05-17-2017 | 01:58 PM
Default 1993 fountain lighting fuse
Hey guys,
Just bought a 1993 35 Lighting Signature Edition and neither of the bolster seats will work. Pumps are Ok and work when you feed them hot from battery. Gotta be a fuse or breaker I'm missing somewhere.
Thanks!
Papasmurf is offline
Old 05-17-2017 | 03:12 PM
VoodooRob's Avatar
Do you have the battery switches to "1" and "2"? Sometimes its the simple stuff like that, dont take offense to the suggestion.
VoodooRob is offline
Old 05-17-2017 | 09:54 PM
My 92 had little circuit breakers undr back seat on the back wall. Other than that there were some fuses under the dash in the middle.
flat rate is online now
Old 05-17-2017 | 10:15 PM
Yeah, I "upgraded" my head unit because of a shorted port battery one time.
1fastlx is offline
Old 05-18-2017 | 07:45 AM
Switches could be bad also. Mine had 1 bad switch.
Crude Intentions is offline
Old 05-18-2017 | 08:57 AM
Mine had melted wiring, corroded connections and melted breakers under the rear seat. Only visible if you took the panel off and flipped it over. I was having another issue with the radio cutting out when other things were activated however which led me to this not the same as what you are describing but may be worth looking into.
Diamond Dave is online now
Old 05-18-2017 | 02:39 PM
Thanks Guys ! Looking at everything this afternoon. Great places to start !
Old 05-19-2017 | 06:47 AM
WOW ! I know a guy like Reggie Fountain, DID NOT, approve the mounting location of that fuse block. Even a 5 year old could never get his hand in there. You have to remove the steering to access a fuse block? WTF
Old 05-19-2017 | 08:54 AM
The glass fuses under the helm?
Old 05-19-2017 | 01:22 PM
Yep!
