Y Pipe Block Off? >
Y Pipe Block Off?
Y Pipe Block Off?
Old 05-17-2017 | 03:41 PM
Default Y Pipe Block Off?
looking for a block off plate or something for my 454 magnum , I deleted the silent choice exhaust and obviously im not pulling the motor to remove y pipe, does anyone know a good quality block off for them?
thanks
Dan
daniel475 is offline
Old 05-17-2017 | 04:13 PM
Have a look here
http://www.cpperformance.com/p-12573...sert-caps.aspx
AllDodge is offline
Old 05-17-2017 | 04:57 PM
Go to hardware store & get yourself a 4" rubber pipe cap and put it on Y pipe with hose clamp.
This works.
ozarkdevil is offline
Old 05-17-2017 | 05:01 PM
http://teaguecustommarine.com/em0011...off-plate.html
Bobbyyeah93 is offline
Old 05-17-2017 | 06:46 PM
This plate is used to block off the exhaust port AFTER you remove the "Y" pipe. The OP stated he was not removing the "Y" pipe.
OP: AllDodge has it right. These are good option.
Aside from that, you should really consider doing this right and pulling the motor to remove the "Y" pipe and properly block off the exhaust port. Once the silent choice is removed the Y-pipe will be unsupported. It is cast aluminum and if it gets a really good whack could crack and then you have a 3" open pipe to the outside. Having said that, plenty of people of just blocked it off without issue; just weigh your risk appetite.
HyFive578 is offline
Old 05-17-2017 | 06:57 PM
jeff32's Avatar
so true!!!
jeff32 is offline
Old 05-17-2017 | 11:22 PM
Personally I would not remove the "Y" pipe, some day someone might want silent choice again.
If you want to spend the extra money for the pretty, fancy plugs from CP let me know I might be able to get them a little cheaper. Other wise go get the rubber plug & double hose clamp it. That will be no different than the rubber coupler from factory.
Old 05-18-2017 | 05:57 AM
SB
Totally agree.
SB is offline
Old 05-18-2017 | 04:09 PM
Ok, 1st thing. Get 2 hardware store caps. Put them on. Launch the boat. Take them off. How close is waterline to top of Y?
dereknkathy is offline
Old 05-18-2017 | 07:36 PM
Why do you care where the waterline is??
