oil viscosity for morel >
Old 05-19-2017 | 06:05 PM
Default oil viscosity for morel
There has been some questions from the Engine Builders that they want to run a 50W oil. The “W” winter rate doesn’t really tell whether you can use a specific oil with hydraulic roller lifters as I have learned from both John Callies and Lake Speed Jr. What does matter is the centistoke number.
Driven has supplied this chart on flow ratings on the Driven FR50 and other popular 50W oils:
Ambient Temperature Oil Flow Rates
Oil Driven FR50 VR1 Brad Penn
SAE 5W-50 20W-50 20W-50
60F 328 cSt 786 cSt 627 cSt
75F 213 cSt 451 cSt 373 cSt
90F 144 cSt 275 cSt 235 cSt
High Temp Flow (for reference)
275F 9 cSt 9 cSt 9 cSt
300F 7 cSt 7 cSt 7 cSt
I have talked with John Callies at Morel about the Data above and he said the FR50 will work with the Morel lifters. For those that want to run a heavier oil you can run this with your Morel lifters.
Chris Straub,
roguediesellogo_1446662629__896381
this is a quote from a friend
adk61 is offline
Old 05-19-2017 | 07:00 PM
A few sets I retailed would only quiet down with cheap 5w-20. I'm done with them. The good cranes run quiet and last. With any oil.
Unlimited jd is offline
Old 05-19-2017 | 07:23 PM
SB
I've seen this plastered all over the net today, and started really looking at Kinetic Viscosity. Which uses the cst number.
Question, why can't someone use another 5W-50 ? Their are very good oils out there that have 5w-50 designations.
SB is offline
Old 05-19-2017 | 07:52 PM
F-2 Speedy's Avatar
I think preload is key to making these work
F-2 Speedy is offline
Old 05-19-2017 | 09:46 PM
I would agree but.... I ran them at 1/2, 5/8, 3/4 and 1 full turn past 0 lash. Only thing that changed noise was piss water oil
Old 05-20-2017 | 06:15 AM
and changing them out for some other lifter.
sutphen 30 is offline
Old 05-20-2017 | 06:21 AM
SB
Since cSt is heavily reliant on oil temperature, let me guess, they'll want those using Morel lifters to run a certain maintained oil temp too........please.
SB is offline
Old 05-20-2017 | 06:22 AM
SB
That's seemingly been the fix.
SB is offline
Old 05-20-2017 | 06:49 AM
F-2 Speedy's Avatar
7/8's is the sweet spot..........
Old 05-20-2017 | 07:32 AM
Ditch the morels... run johnsons
1MOSES1 is offline
