Rebuild Kit
Old 05-20-2017 | 07:16 PM
Rhythm and Blues's Avatar
Default Rebuild Kit
Evening fellas, could anyone tell me which rebuild kit I'd be looking for for the pictured pump.
https://www.ebay.com/p/?iid=27230766...7661918&chn=ps
Attached Thumbnails Rebuild Kit-img_2599.jpg   Rebuild Kit-img_2600.jpg   Rebuild Kit-img_2601.jpg
Rhythm and Blues is offline
Old 05-21-2017 | 09:01 AM
Ayuh,..... That's the current production trim pump,.....
Whatever part number Merc lists for it is the one,....
What's the Issue yer tryin' to fix,..??
Bondo is online now
Old 05-21-2017 | 09:46 AM
Roger that, appreciate the heads up..
In no premeditated order I'm fussing with a drifting/tucking drive...
Old 05-21-2017 | 04:21 PM
Gotcha,....
I sometimes use a little brass rivet to isolate whether it's 1 ram or the other, or the pump,....
Run the drive full up, support the drive at full up,...
Disconnect a line or lines where ya gonna test, slip the rivet into the tubin', 'n put it back together,....
The little soft brass rivet conforms to the inverted flare, blockin' off that circuit,...
Pull the support from the drive, 'n wait for it to drop,...
You can also find automotive brake line fittin's that are the same as our trim line fittin's,...
3/16", 'n 3/8" I believe,....
Caps aren't common, but they are out there,....
Plugs are easier to find,...
Bondo is online now
Old 05-21-2017 | 04:30 PM
Gotcha,....
Thanks, I didnt know about the brass rivet trick.
