Shifter
Old 05-24-2017 | 05:32 AM
Default Shifter
Due to the increase in power and recommendation of both Hydromotive and Herring propellers I am changing my prop from right handed to left. My understanding that you can just change the cabling on my shifter control. Has anyone done this and if so can you explain it?
proscapes199 is offline
Old 05-24-2017 | 08:57 AM
I did not physically do mine myself, but I did the same last year when I had engine rebuilt. You will like the outcome. The boat will ride totally true at cruise, rather than having to drag the port side tab to keep the boat level. Going to lefty will counter act the engine rotation. The marine shop that did my engine and drive did the work for me but I was told it was as simple as changing the cables on the shifter. Hope this helps a little.
29Fever01 is offline
Old 05-25-2017 | 05:37 AM
Thanks for your response looking for the results.
Old 05-25-2017 | 09:48 AM
Look at the bottom of your shifter. The cable needs to swap sides. If it's on bottom it has to go on top or vice versa. Basically you switching the push/pull. If it's pushing the cable in forward now then it needs to pull in forward when swapped.
Crude Intentions is offline
Old 05-25-2017 | 10:09 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
BEFORE you go through the work of changing the shifter over (again, not a huge task), go run the boat with just using the shifter in the opposite direction. Your Bravo drive knows no difference b/t forward and reverse technically speaking.
Take a look under your dash at the shifter lower half. You will see one ear that has the cable attached, and one not used. Just swap the cable end over to the other one. You may need to move a few zip ties.
Sydwayz is offline
Old 06-04-2017 | 10:20 PM
Very simple to switch. I'm in Cleveland as well if you need any help let me know. I believe you're by little Vellas correct?
89Mach1 is offline
