crane HI 6M manual needed and/or advise
putting back together a set of engines with Crane HI 6M boxes and new MSD distributors but I have no paperwork on the boxes. anyone have a manual or can tell me what the timing settings for each position are? I assume that if using the built in timing curve the dist needs to be locked and phased? if so what do you set the timing to. I assume base timing is taking into account what the curve is for each position setting on the box? hopefully someone knows what I need to do to set these up. thanks
