Dual batteries or will a booster pack suffice? >
View Poll Results: Dual batteries or carry a jumper pack
Dual batteries
14
82.35%
Jumper pack
3
17.65%
Voters: 17. You may not vote on this poll
Old 06-05-2017 | 04:21 AM
rak rua's Avatar
Default Dual batteries or will a booster pack suffice?
My latest ride has a single 496HO and I am surprised it only has a single battery but the engine bay looks super clean and simple, which I really like. One battery, one set of cables and one on/off switch. It will probably be used once a month and we don't have back up like SeaTow so one battery on its own is not wise. The boat only has a modest stereo and no fridge or other things to drain the power.
Obvious answer is to install another battery but rather than complicate everything and have another battery to keep an eye on, would you feel secure with just a good quality booster pack? Carry it onboard at the start of the day and take it home afterwards. Cost isn't the issue, I'm thinking about simplicity in a boat that won't be used a lot. I'm only wanting to cover an emergency start then I'd cut the day short and head home.
Tell me I'm off my nut if you think so, any input is appreciated.
RR
rak rua is offline
Old 06-05-2017 | 05:27 AM
I can tell you that the 496's like a full charged battery, I'd see how it rides and if it needs weight moved around just mount a second battery. What did you get??
class6 is offline
Old 06-05-2017 | 05:38 AM
rak rua's Avatar
Thanks for your input, I bough a 27ZR. (I hope it does what I want!)
Battery is on the starboard side, way back almost against the transom. With the dual battery option, the second one is opposite on the port side. Don't think weight distribution would be significant. if I go for dual batteries, I'm sure the port side is the right place.
The boat is still 6 weeks away, it's a long wait..............
RR
rak rua is offline
Old 06-05-2017 | 08:17 AM
I don't see any need for a 2nd battery. The jump pack idea seems like a sufficient back-up.
BenPerfected is offline
Old 06-05-2017 | 08:35 AM
I have dual batteries in my 27 ZR. Both are on the starboard side. I also ALWAYS carry a jump box, it has saved myself and others many times.
https://www.amazon.com/STANLEY-J5C09...anley+jump+box
This is the one I have, motor will start without hesitation.
TorchLK is offline
Old 06-05-2017 | 08:38 AM
SB
It's up to the boat owner......your decision.
A dead/shorted battery that won't accept a charge can be very interesting to try to drive home once started - even with a jump pack attached. Tough with a carbureted engine, brutal with a FI engine.
SB is offline
Old 06-05-2017 | 08:45 AM
rak rua's Avatar
Thank you "Torch".
I've seen pics of others with the second battery on the port side. They're always changing things in production so I guess the boat isn't that finely balanced to make a difference.
Im leaning towards the jumper pack at the moment.
Thanks.
RR
rak rua is offline
Old 06-05-2017 | 08:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do you plan to use the stereo while you are out during the day, docked, rafted, whatever? I'd go with the second battery.
Sydwayz is offline
Old 06-05-2017 | 09:58 AM
I'm glad to know the cats out of the bag on what Donzi model you bought, my .02, good choice. With the battery debate it's goes both ways. If I have only one battery I buy the biggest deep cycle j can. I have listened to my sterio at almost max all day on one and it fired up my 440 that had an old starter that wasn't the best. The boat had a second battery I just didn't use it that day because I wanted to see if it would do it. Now my 22 donzi only has 1 battery and I haven't had any issues with it either. As long as your charging system works you should be fine. I would only be worried if I was over nighting on the boat and had something running the whole night. The jump pack should get you started and the alternator should do the rest once running. Just my opinion.
DBleil89 is offline
Old 06-05-2017 | 10:02 AM
My Velocity 280 only had one battery, the VR 1 has two. Never had an on the Water problem with either but i really like that I now have a back up battery. Was always going to add a second to the 280 but never did.
padraig
Padraig is online now
