What diameter to go with >
Old 06-08-2017 | 11:23 AM
Default What diameter to go with
Wondering if anyone could help me with my prop diameter question both props I currently run are 14.25 diameter
1st one is a 21p vengeance which I like but it runs my boat on the rev limiter at 57 mph on gps
2nd one is a 22p turbo that drops me down to around 4600 and leaves me at about 55-56 mph on gps
my question is do I go bigger diameter on a 21p or smaller diameter on a 22p for my next prop any help would be great
Trytten1 is offline
Old 06-08-2017 | 11:52 AM
SB
If it's a small block, alpha, and light or semi light boat they seem to like smaller diameter props...cleavers exempt. But, ultimately, your boat will decide.
Maybe try the next Vengeance up a size.
SB is offline
Old 06-08-2017 | 12:18 PM
I have tried the vengeance in a 22p 14.25 dia. With same results the boat has a 300mag mpi with a bravo 1 drive
Trytten1 is offline
Old 06-08-2017 | 12:42 PM
SB
Still hits rev limiter....go up another.
SB is offline
Old 06-08-2017 | 12:45 PM
SB
Mercruiser does not list Vengeance in a 22P.
https://www.mercurymarine.com/en/us/...ies/vengeance/
SPORT SERIES
Vengeance®
All-around star performer.Quality, durability, value.
  • Available pitches 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 21, 23, 9, 9.5
  • Rotation LH, RH
  • Performance vent system (PVS) No
  • Boat types Bass, Cruiser, Deckboat, Houseboat, Inflatable - Soft Hull, Inshore Fishing, Offshore fishing, Pontoon, Runabout - cuddy, Runabout - open bow
  • Number of blades 3
  • Material Stainless Steel
  • Fits Alpha drive, Outboards 20hp - 250hp
Find a dealer
=1069]Compare
SB is offline
Old 06-08-2017 | 12:49 PM
SB
21" Vengeance listed as 13.75 Diameter.
23" Veneance listed as 14.25" Diameter Scratch this, I see some state that this has 13 1/2" diameter....so I really don't kno which it is at this point.
SB is offline
Old 06-08-2017 | 12:55 PM
Sorry the 22p vengeance leaves me at around 4600 rpm not on the rev limiter like the 21p I thought about getting a enertia but they are a little pricey so that's why I'm looking for some tips I like the hole shot of the 21p but didn't no how much bigger I should go diameter to drop me down to that 4800 mark thanks for the help
Trytten1 is offline
Old 06-08-2017 | 12:57 PM
I'm almost positive it is a 22 vengeance I'll have to look at that again tonight
Trytten1 is offline
Old 06-08-2017 | 03:02 PM
bbladesprops's Avatar
Offshoreonly Advertiser
There are no 22 Vengeance.
On a pplication such as yours, diameter isn't as big of a factor as some other set ups. You need to be most concerned about pitch to control rpm and number of blades to control the boats personality.
Brett.
[email protected]
bbladesprops is offline
Old 06-09-2017 | 08:56 AM
So you guys were right ive true a 22p renegade and 22p Turbo the 21p vengeance I'm running is 13.75 diameter
Trytten1 is offline
