502 oil capacity with relocated oil filter >
Old 06-09-2017 | 04:38 PM
Default 502 oil capacity with relocated oil filter
What should capacity be? New purchase and when cold and level ground dipstick shows about 2 inches above full mark? I took to local dealer to get shift cable adjusted and they told me it didn't have any oil showing on dipstick....then they tell me they checked it running. lol I know right....thanks
Force265 is offline
Old 06-09-2017 | 04:42 PM
F-2 Speedy's Avatar
I think thats the wrong dip stick, unless its way over full, I think a gen 6 502 has an 8 or 9 qrt + the filter, lines and cooler
Checking it while running ?? find a different shop......
F-2 Speedy is offline
Old 06-09-2017 | 04:48 PM
SB
Actually , the best time to check it is when airborn just after launching off a big wave. If you land before you see the oil level, do it again.
SB is offline
Old 06-09-2017 | 05:03 PM
Default Lol....
I'll try that sb....lol
Force265 is offline
Old 06-09-2017 | 05:05 PM
The first launch I was seeing about 40 lbs at idle and 60 running about 3200
Force265 is offline
Old 06-09-2017 | 09:01 PM
Is it a Merc 502???? If so, it holds 8 qts if 100% empty. 7.5 qts is what gets me to the full mark when I do an oil change on my 502mpi's.
Check the oil with engine level. This is the same as it would be sitting at rest in the water.
Griff is offline
Old 06-10-2017 | 01:33 PM
Yes it's a merc. And thank you I will check on next launch
Force265 is offline
Old 06-10-2017 | 05:52 PM
Mine with filter is a tad over 7 quarts with filter WIX 51060R
AllDodge is offline
