540 whipplecharged stalls coming off plane >
Old 06-21-2017 | 06:56 PM
Default 540 whipplecharged stalls coming off plane
have a 540 whipplecharged BBC. Runs absolutly great, for some reason this year it started stalling when you would come off plane. Pulling back on throttle easy, around 800-1300 rpm that's when it dies. It gives alittle spit or pop, like a misfire out the intake. Not sure if it's a fuel pressure issue, IAC , throttle blades not open enough??? Spark arrester blades are clean, IAC filter is clean. I have 28-30psi fuel pressure at idle and WOT. Aeromotive 1000 pump. After a stall it does re start right back up, no issues. Just not a good feeling when it stalls off plane. Any suggestions would be greatful, I'll be calling my engine builder on the weekend.
Thanks jason-
Bajajay98 is offline
Old 06-21-2017 | 07:51 PM
Check fuel filters if it is a new simptom
Swamplizard is offline
Old 06-21-2017 | 07:59 PM
jeff32's Avatar
Same thought here!
jeff32 is offline
Old 06-21-2017 | 08:04 PM
Why would you say it's a fuel filter issue if I have solid fuel pressure ?
Old 06-21-2017 | 08:35 PM
What EFI setup is on it?
That FP seems low
TooLateVTEC is offline
Old 06-21-2017 | 08:39 PM
Should be the set up that came with either the factory 525 merc or Whipples program. I swear the FP was suppose to be 58-60 psi with a whipple set up
Old 06-21-2017 | 08:44 PM
I dont know of an EFI setup off hand that would run with 30 psi. Most are 58-60 like you said.
Checking/cleaing/replacing the filters is a good place to start for sure, especially since it didnt do this before.
Old 06-21-2017 | 08:48 PM
Tinkerer's Avatar
Sounds like a lean pop to me. POP through the intake at any RPM usually means lean spot.
Tinkerer is offline
Old 06-21-2017 | 08:54 PM
SB
So, don't run it again until you get word on what fuel psi is supposed to be. Lean is mean, puts a torch on the pistons and likes to rattle things.
Your builder only works on week-ends ?
SB is offline
Old 06-21-2017 | 08:55 PM
Turbojack's Avatar
Bad IAC
Turbojack is offline
