Distributor gear
Old 06-24-2017 | 09:14 AM
Unhappy Distributor gear
Anyone have idea what can cause a gear too go bad on a MSD dist.could the cam be an issue also
Sieg66 is offline
Old 06-24-2017 | 09:22 AM
SB
What is the cam gear material ? What is the distributor gear material ? And yeh, alignment can do it too + it amazes me how many people install distributor's dry.
Also, do you have the o-rings installed on the MSD dist or did you leave them off ?
SB is offline
Old 06-24-2017 | 03:13 PM
BUP
And checking the depth of gear in relation to. That is very important as well. Just adding info
BUP is offline
Old 06-24-2017 | 06:47 PM
Default Gear
Second time this happened, installed a melonised gear, don't know if I spelled that correct.. lol going too spec check it all upgrade too newer distributor and go from there.. thanks for input
Sieg66 is offline
Old 06-24-2017 | 06:54 PM
SB
English please. Me no comprendo.
I did understand the melonized gear on the dist, and 2nd time this has happened, but understood nothing else. Could you answer the questions put forth so that we may assist you further ?
SB is offline
Old 06-26-2017 | 01:25 PM
I was told on the hydrolic roller cams the gear is harder then then one on the distributor. I was told to run a brass or composite gear in the hydrualic roller motors. A marinia out annold thunderbold VI in my brother in laws 97 454 and it wore out the factory gear in 2 seasons. We bought the composite and havent had any issues in 4 years
DBleil89 is offline
Old 06-26-2017 | 10:25 PM
cigrocket's Avatar
I had a distributor that was a hair out of round....bent and it caused the distributor gear to be chewed up. Just an FYI
cigrocket is offline
Old 06-26-2017 | 10:58 PM
almost all dist gear failure,s are due to using the wrong gear.not all hyd roller cam gears are made from the same metals.
mike tkach is offline
Old 06-27-2017 | 05:59 AM
SB
Always amazes me people that have issues and take the time to start a thread don't answer important questions asked to help with the repair.
SB is offline
