Bimini top 38 Cig T/G >
Old 06-25-2017 | 10:15 AM
lucky strike's Avatar
Default Bimini top 38 Cig T/G
Where can I get a aluminum Bimini top for a 38 Top Gun. locally So. FL. New or used.
I have a stainless one from a Cafe Racer if anybody is interested
lucky strike is offline
Old 06-26-2017 | 09:56 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Check with Pat over at Active Thunder and see who he uses. He's had several made for boats in the past few years that are good at speed.
You definitely want all stainless tubing, and through bolts, not screwed into the fiberglass.
Sydwayz is offline
Old 06-27-2017 | 06:34 AM
Stainless X2....I would definitely go for the stainless frame, you will be able to cruise with the top up if desired.
kreed is offline
Old 06-27-2017 | 08:11 AM
rak rua's Avatar
I had a stainless Bimini made for my last boat and it secured to a very sturdy stainless arch. I could run up to top speed (high 60's) and she held tight but I'd say it was on the limit. 40-50 cruise was pretty comfortable.
I think an aluminum one would have simply folded up, with the Sunbrella working a bit like a sail, they take a real beating over about 40 mph. Go stainless.
Boating in the shade is just as much fun as boating in the sun!
RR
rak rua is offline
Old 06-29-2017 | 06:13 PM
I have a red one stainless tubing with boot $900
90viper is offline
