HELP!!! 2000 7.4 mpi >
Old 06-26-2017 | 11:50 AM
Default HELP!!! 2000 7.4 mpi
hi I need the fel-pro part# for the headset and the upper intake manifold set... try to get the boat ready for the 4 july weekend help help help
Onthewater_ is offline
Old 06-26-2017 | 01:06 PM
17046 head gasket
MichiMike is offline
Old 06-26-2017 | 01:13 PM
SB
Originally Posted by MichiMike
17046 head gasket
I believe those are for Mark IV.
The OP has a 2000, so should be Gen VI
SB is offline
Old 06-26-2017 | 01:30 PM
no they fit 5/6 just did mine gen6 7.4
Old 06-26-2017 | 03:56 PM
Just did a little more Diggin I've got a gen vi non-adjustable rocker
still looking for the headset part number
Old 06-26-2017 | 04:55 PM
Head gaskets or head set? Valve cover gaskets reuse well. Exhaust gaskets are best to get Mr. Gasket 454 header gaskets. Probly don't need valve seals. So you need head gaskets and intake set from 97 suburban with 7.4 engine from auto parts store.
dereknkathy is offline
Old 06-26-2017 | 05:32 PM
you need a set of fel pro 1037 head gaskets .a lot of intake gaskets will work but i like the mr gasket #121 and a smear kote of the right stuff around the ports,like derek said you can reuse the valve cover gaskets.
mike tkach is offline
Old 06-26-2017 | 06:03 PM
Thanks guys
Just brought the boat to find out that the motor had a blown head gasket's and had to take the heads in to get machine because they're warped
That's why the headset thanks guys appreciate it
