Can't find a starter >
Old 06-29-2017 | 11:39 PM
Default Can't find a starter
What starter fits a 4 cylinder gm block with casting number14097080 and stamping number 2m03103 it is in my 1997 chaperell boat. Bought it from auction and was missing the starter. I'm assuming the engine has been replaced. Thanks.
180le is offline
Old 06-30-2017 | 05:11 AM
Ayuh,..... The odds are it's got a 12" flywheel, 'n straight across bolt pattern,.....
I've never seen a 2.5l or 3.0l with the 14" flywheel, 'n staggered bolt pattern starter,....
Bondo is offline
Old 06-30-2017 | 10:42 AM
Bolt pattern is staggered
180le is offline
Old 06-30-2017 | 11:00 AM
You're sure there's not three different starter bolts down there? Because that engine usually has the small flywheel and the two straight parallel bolts. Before you do anything, get down there with a big screwdriver and see if you can turn that flywheel with the screwdriver. That's probably a reason that starter got taken off that boat and then the boat sold at auction. If that's a seized engine you might be starting from scratch, not worrying about which starter it takes.
dereknkathy is offline
Old 06-30-2017 | 12:30 PM
Checked engine, not seized, there is a a hole straight across but is a larger size and shallow. The starters that are supposed to work don't get close enough to even try the bolts before the solinoid is interfering with the engine.
180le is offline
Old 06-30-2017 | 12:43 PM
From the Internet research I've done I gather that engine is an industrial gm vortex 3000 but the stamping number doesn't line up with any of the charts I've found.
http://www.ascendtech.us/gm-3-0l-i4-4-cylinder-industrial-engine_i_clenggm14097080.aspx
180le is offline
Old 06-30-2017 | 01:07 PM
Which side of the engine is the starter going on?
Old 06-30-2017 | 01:08 PM
Which side of the engine is the starter going on? Sounds like you are trying to put it on the left.
Old 06-30-2017 | 05:00 PM
Ayuh,.... Chevy marine starters only come 2 flavors,.... Staggered, 'n straight across bolt patterns,....
Never seen any with the solenoid clocked any differently,.....
Is the straight across hole got a broken bolt stuck in it,..??
This would probably easier if ya Id the motor, as in a Merc 3.0l, Alpha, Gen.II drive, or whatever's in yer Chaperell
Bondo is offline
Old 06-30-2017 | 07:35 PM
fork lift motor. used to be in chevy mail trucks and 67 4 cyl nova's. chevy 250 six with cyl number 3 and 4 missing. staggered bolt chebby starter. I think they stopped using little flywheels in the 80's. this New Starter Chevy 305 350 454 Mini Racing PMGR High Torque 323-436 10095 10099 | eBay or this 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 CHEVY CAMARO STARTER MOTOR 8 CYL MT | eBay this type will really clear engines. Proform 67052 High Torque Mini Starter - Chevy V8 168 Tooth Staggered Mount | eBay also called a 3508 or 3510.
