New transom, what angle to drill Drive trim indicator cables >
Old 06-30-2017 | 11:39 AM
Default New transom, what angle to drill Drive trim indicator cables
New transom, what angle to drill Drive trim indicator cables?
ON a 33 AVS 2000. It has little chrome cover where they passed through. I did not not the angle of the cables before I replace the transom.
cyrus77 is offline
Old 06-30-2017 | 12:11 PM
Same angle as transom.
https://www.harborfreight.com/angle-...ide-95622.html
Blueabyss is offline
Old 06-30-2017 | 07:18 PM
Order these. Mount on transom and use as a jig. Very nice and clean.
Stainless Cable Thru-Hull Fitting, 45 Deg - CP Performance
Crude Intentions is offline
Old 06-30-2017 | 09:28 PM
that's what I did and cut the angle it is.
Clean install.
Wildman_grafix is offline
Old 07-01-2017 | 12:35 AM
So it is not the same as the transom. But the drill attachment is grteat.
The angle fittings are nice. and they are about 45 degrees right. Really nice looking! it says 1/2 inch I though the cables were smaller than that?
cyrus77 is offline
Old 07-01-2017 | 05:24 AM
They have gaskets in them. Once the cable is through you install a rubber seal then a plastic piece then tighten down.
