bplace to mount oil temp gauge sending unit?
Where would be the best including simple place to mount sending unit for the oil temp gauge on a 6.2 Mercruiser? Trying to keep it simple as in not drilling into pan or anything but in a spot that will read it ok.
better down in oil flow. once it is in pressure sender pipe, it is kind of stagnant and I don't think give you a good temp reading. here. https://www.google.com/search?q=350+...=1498870089640
That is where my oil pressure sending unit is at. I thought there were other locations on the block where this could be added for some reason. Might wait till next oil change to add it and put it in drain plug hole in pan.
