Crazy Alarm help
Hi folks. My first time asking for help. I have a 41 PC with twin (2000 502's). The port engine alarm will go off after about 20-25 min of 3000rpm run and I shut her down immediately. However, I can run for a while at idle or near idle with no issue. So far I've replaced the impeller and also the oil pressure and engine temperature are both within spec. Also, by doing a search on the interwebs I noticed that low voltage can also trigger this issue. All the batteries have plenty of voltage.
What should I look for next?
Thanks,
Tim
Thanks,
Tim
