Afr numbers
Old 07-06-2017 | 01:10 PM
Default Afr numbers
like to see what people have for afr numbers on there na bbc
i am at 14.5
dspad is offline
Old 07-06-2017 | 01:56 PM
watching
GLENAMY 242SS is offline
Old 07-06-2017 | 03:29 PM
i am at 14.5
I hope that is at idle. That's way to lean under load
edelectra is offline
Old 07-06-2017 | 04:20 PM
12.1 wot
cjo632racing is offline
Old 07-06-2017 | 06:13 PM
Nope at Cruz 4k goes to 14 at wot I think my gauge might be bad as it ran at 16 last year wot and have not melted it down
dspad is offline
Old 07-06-2017 | 07:45 PM
The consensus of the brain trust in the tech section *circlejerk was happy keeping it in the 12s with the EFI folks being happy with it in the lower 13s. Subtract a full point for boost applications.
*circlejerk was a handy and fun resource but seems to have disbanded after the recent overhaul.
Baja Rooster is offline
Old 07-06-2017 | 08:16 PM
On a natural. Marine motor I like 13s on cruze and mid 12s at full load , just my opinion. Good luck
Old 07-06-2017 | 08:41 PM
Okay changed primary Jets from 83 to 84 stock is 82 secondaries where 92 went to 94's which is stock installed 6.5 power valve had a 5.5 noticed the bowl behind the power valve was dry not sure if it's supposed to be like that
ordered a new digital afr meter was using an analog one needle type there were some complaints of it locking up at 14.2 which has happened to me auto meter said could be bad ground or bad power at times the needle would clock for five or six minutes before reading the value or if I cycled the motor on a restart the needle or gauge would read
looked at my Dyno paperwork afr was 12.1 to 14.2 rpm is 3500 to 6000
Ibut I did change intakes this year went to a brodix hvh high rise runners
dyno intake was a med rise short runner Merlin intake with small runners
dspad is offline
Old 07-06-2017 | 08:51 PM
Full Force's Avatar
14's?? yikes!!
I run full time widebands, I see mid to high 12's cruising, 12.2 ish WOT... if it varies a ton you might wanna have some carb work done... AF should not change that much throughout powerband...
Full Force is offline
Old 07-07-2017 | 12:56 PM
splashandburn's Avatar
So are you saying that with a Procharger EFI application you should be.looking for low 12's @ WOT? Working on tuning mine now so just curious.
splashandburn is offline
