silent choice question
Old 07-10-2017 | 10:00 PM
Default silent choice question
so I want to add silent choice to my boat,,boat has merc 496 HOs,,found a couple of used set of off 502s but was told they are different and will not fit a 496,,does anybody know what the difference is?
boatnt is offline
Old 07-11-2017 | 06:16 AM
Call the manufacturer of the silent choice and see if they will fit. I'm sure there are some kind of identification on them a
3pointstar is offline
Old 07-11-2017 | 06:22 AM
I did,,they said their book shows a different part numbers,but they do not know what the difference are,LOL
boatnt is offline
Old 07-11-2017 | 06:44 AM
Knot 4 Me's Avatar
Has to do with the differences in the risers between the two different style exhaust I would imagine. Any reason to choose silent choice over switchable mufflers?
Knot 4 Me is offline
Old 07-11-2017 | 06:59 AM
the Y pipes are allready there so I thought it would be a easy install,,
so are you saying the difference would be in the length of the tube going to the Y pipe? because I would think the angle would be the same because the Y pipe is the same for both applications,kind of what I was thinking
boatnt is offline
Old 07-11-2017 | 07:44 AM
Its probably the length of the pipe going to the Y pipe. When I went from stock manifolds to Eddie marine I had Corsa add some length to this area. Later during my rebuild had to go to even higher exhaust so I removed the diverters and set them on a shielf
AllDodge is offline
Old 07-11-2017 | 08:23 AM
Knot 4 Me's Avatar
Just going off of past visuals I would think there is a difference in the height of the exit points of the risers and possibly even a bit of the angle. Not sure just guessing those would be the differences between the two. Surprised your Fountain did not come with silent choice yet they installed and then blocked off the y-pipes. I've never been a fan of the pipes being there and capped. Just makes me nervous!
Old 07-11-2017 | 08:25 AM
thats what I was thinking,,If that is the only difference I should be able to replace the 4" hose that is between the Y pipe and the diverter with a longer piece ,right?
boatnt is offline
Old 07-11-2017 | 08:27 AM
Maybe, depends on the angle
AllDodge is offline
Old 07-11-2017 | 08:30 AM
[QUOTE=Knot 4 Me;4568092]Just going off of past visuals I would think there is a difference in the height of the exit points of the risers and possibly even a bit of the angle. Not sure just guessing those would be the differences between the two. Surprised your Fountain did not come with silent choice yet they installed and then blocked off the y-pipes. I've never been a fan of the pipes being there and capped. Just makes me nervous![/QUOTE
no the Y pipe is not capped off,right now the boat has thru hull and Y pipe exhaust working together,,it has what looks like diverters but has nothing inside the diverters ,,so some exhaust exist out the Y pipe and some out the Tips,,actually not a bad set up,,
boatnt is offline
