Gauges?
Old 10-14-2002 | 05:46 PM
Question Gauges?
Been looking for new gauges. How important is an oil temp gauge? I'm looking for white faced gauges and all that I have found don't offer the oil temp gauge. Anyone know of a company that sells them? Thanks in advance, 88Mach 1
88 MACH 1 is offline
Old 10-14-2002 | 05:53 PM
bajadude's Avatar
IMHO oil temp is very important especially if you're running a performance motor. I've had boats with 7.4, 454 MPI and 496 and none of them had an oil temp gauge. With my HP500s, its a must. Have you looked ay Gaffrigs yet?
What are you running?
bajadude is offline
Old 10-14-2002 | 05:55 PM
later's Avatar
oil temp can tell you if you got something not right before you really tear something up are get stranded
later is offline
Old 10-14-2002 | 06:29 PM
Default bajadude
I'm running a 454 with 500 hp. An all roller set up. I really want white faced gauges. I'll check out Gaffrigs. Do they have a web site? Thanks, 88 Mach 1
Old 10-14-2002 | 06:44 PM
bajadude's Avatar
Here's the site Livorsi (Livorsi is Gaffrig)
You can also get them (cheaper) through Nisonger Marine, Teague
and most of the other distributors
Hope this helps
bajadude is offline
Old 10-15-2002 | 08:06 AM
ursus
Oil temp is probably the most important guage, it tells you when there "is" a problem, water temp tells you when there "was" a problem,, water temp is still necessary tho don't eliminate int
Elite Marine
Baja
5
03-16-2008 07:58 PM
thedonz
12-29-2005 10:34 AM
Ric232
4
05-17-2003 08:01 PM
Steve A.K.A RAMPAGE
4
04-24-2003 07:35 AM
Elite Marine
Pantera
0
02-26-2003 10:10 PM
