Fuel in oil. Port side >
Old 07-16-2017 | 11:43 AM
Default Fuel in oil. Port side
I'm getting gas only in my port side exhaust. The block has 0 hours on it. All of the injectors have been cleaned and serviced. I even changed the computer on that motor. Not sure what to do now. 'My mechanic is stumped also??
Dmsroxstar is offline
Old 07-16-2017 | 12:39 PM
F-2 Speedy's Avatar
What engine is it 454 - 502 mag with vst ? the title and content of the thread are two different things, does it run
F-2 Speedy is offline
Old 07-16-2017 | 01:58 PM
Default Yes 502 with the vst
Yes 502 with a vst
Old 07-16-2017 | 01:59 PM
And getting gas in the oil
Old 07-16-2017 | 03:56 PM
F-2 Speedy's Avatar
and you know this how ??...I'll ask again, does the engine run
Old 07-16-2017 | 04:00 PM
camptappakeg69's Avatar
Think vst overflow dumps into a intake port on that side if it was malfunctioning, at least it did on mine....
camptappakeg69 is offline
Old 07-16-2017 | 06:33 PM
Yes, it runs . On the hose, starboard side exhaust is clean fresh water, port side is full of fuel, its white and beads up on your hand and smells of gas. Also after running 5 min on the hose the oil smells like gas
Old 07-16-2017 | 07:35 PM
F-2 Speedy's Avatar
Im not well versed in VST, camp 69 may be onto something, excessive amount of fuel ( flooding ) could wash down the cylinders push it passed the rings and into the pan
Old 07-16-2017 | 08:46 PM
Mechanical fuel pump? Another possibility
dereknkathy is offline
Old 07-17-2017 | 12:05 PM
Not sure if to much fuel would make the oil white, think water would do that, check the vst, there is a small black hoes that goes directly to a fitting on the intake that dumps excess fuel.
