Anyone Like Twin Turbos Instead of Superchargers?
I have twin roots blowers now but I have been reading about many huge power applications and they use twin turbos.I am thinking to do a rebuild soon and was thinking about the twin turbo setup.But I do not know who makes one good for marine use and also what you professionals have to say.Turbos, supercharged...nuclear pistons etc..??
I didn't chose the turbo life, the turbo life choose me. I have factory Mercruiser twin turbo 454's in my Scarab. They were originally rated at 475 hp. They used a RayJay draw thru single carb system. Gale Banks was the big name for turbos back in the late 70's early 80's I have talked to him on Facebook and he loves seeing the pictures of my setup (brings back old memories for him) Twin turbos are a very custom set up on what ever engine you use, but you will be surprised how nice they are. Very quiet because the turbos muffle the roar, but the turbine whine is like a jet taking off. I don't think anybody makes a bolt on system. If you talk to knowledgeable turbos shops like Sterling or Boostpower, Im sure they can steer you in the right direction. Look up Carson Brummett over at Performanceboats.com for more turbo information. I talked to him on the phone and he was the nicest guy and told me everything I needed to know and how to set up my engines using the existing carbs.
A problem with turbos on boats, is they don't start to make boost until the revs are up. But you got to get the boat to come up on plane when the revs are down. And boats are by design a 1 speed transmission. And propped to get the maximum out of it at essentially Full Throttle full speed. Those roots style blower give you boost right from the minute you hit the gas. So they help to get the boat up and onto plane.
i didn't chose the turbo life, the turbo life choose me. I have factory mercruiser twin turbo 454's in my scarab. They were originally rated at 475 hp. They used a rayjay draw thru single carb system. Gale banks was the big name for turbos back in the late 70's early 80's i have talked to him on facebook and he loves seeing the pictures of my setup (brings back old memories for him) twin turbos are a very custom set up on what ever engine you use, but you will be surprised how nice they are. Very quiet because the turbos muffle the roar, but the turbine whine is like a jet taking off. I don't think anybody makes a bolt on system. If you talk to knowledgeable turbos shops like sterling or boostpower, im sure they can steer you in the right direction. Look up carson brummett over at performanceboats.com for more turbo information. I talked to him on the phone and he was the nicest guy and told me everything i needed to know and how to set up my engines using the existing carbs.
IMO That statement is not true. If a turbo is setup properly it will build boost in the lower rpm also. Look at all the Mercury turbo motors available today. Those engines are in boats that go 150+mph and have no issues.
It does not seem like it should be a problem for a boat with turbos, like someone said they dont build power fast.If you are at a stop and you raise the rpms to 4000 for example the motors should being spinning and moving air and this should move the horsepower fast maybe not as fast as a roots blower but enough to get it on plane and then it will be making big power.
I can't say I know of anybody who goes WOT out of the hole to come up on plane? By the time you're up and moving fast enough to not blow out the props, the turbos would easily be spooled from the load.
