Input shaft for new style (sloped) Bravo X same as XR or different? >
Old 07-16-2017 | 02:22 PM
Default Input shaft for new style (sloped) Bravo X same as XR or different?
Getting a newer X drive that is missing input shaft and ujoint,,was told its different than standard bravo.. Will xr fit or the X different from that as well.. also can u-joint be replaced? Does it use different gimble bearing or is there an adapter shaft to go from an x/xr drive to a bravo 1 gimble bearing? Thanks!
HTRDLNCN is offline
Old 07-16-2017 | 05:23 PM
Just get the X/XR input shaft assy....you'll want the red dot or white dot gimbal bearing
JaayTeee is offline
Old 07-17-2017 | 09:37 AM
dont need the whole assembly,, just the engine/boat side which I found here on swap shop for $180 and the u joint..
HTRDLNCN is offline
