Shift interupt 700 sci >
Old 07-16-2017 | 05:36 PM
Default Shift interupt 700 sci
Hello Gents
i have a problem with my 700 sci fountain 42
when i connect the shift interupt on both my motors they wont rev past 1000 rpm , when we disconnect it the motor runs normal . We changed the shift interupt switch and it does the same ?
Could it be the lower shift cable ?
any ideas to help a fellow boater ?
Ace snake is offline
Old 07-17-2017 | 06:28 AM
Ayuh,.... What drives ya got,..??
Bravos don't use the shift switch,....
Bondo is offline
Old 07-17-2017 | 07:25 AM
nxt's do tho
JaayTeee is offline
Old 07-17-2017 | 10:35 AM
BUP
all Bravo's and alpha s have a shift in gear switch using ECM - PCM 555 and PCM 09 and up
BUP is offline
Old 07-17-2017 | 05:23 PM
Ayuh,.... It was a Guess, 'n I guess I guessed wrong,....
Bondo is offline
