Let's blow up my boat ! >
Old 07-17-2017 | 05:17 PM
Default Let's blow up my boat !
How much gas can I pour into my carburetor to try and start the engine and help prime the fuel system once it fires ? I have a fear of exploding bilges.
Recently replaced the remote belt driven fuel/water pump housing and fuel pump plus sorta drained the seperator and fuel line also. I cranked on it and it seems to not prime and don't want to keep beating the starter.
ed
Interceptor is offline
Old 07-17-2017 | 05:20 PM
Fill the bowls till fuel comes out into the Venturi. Take a J tube off and pour it in there
endeavor1 is offline
Ayuh,.... Pre-fill the fuel filter most of the way, 'n splash a "Shot", 'bout an ounce, of gas in the carb's throat,....
It oughta fire right up,....
Bondo is offline
Old 07-17-2017 | 07:55 PM
SB
I cheat. I have a cheapy electric pump with 3/8 rubber hoses attached both sides and alligator clips for the power and ground.
I fill most carb's on my bench after I rebuild them.
In fact, it's same set up I use to remove fuel from fuel tanks when I want to refresh with new. The old fuel goes right into my truck's gas fill.
edit in: always fill water separator/ fuel filter when ever one get's installed.
SB is offline
Old 07-17-2017 | 08:06 PM
Thanks guys. If you don't hear from me tomorrow you'll know I screwed up.
Old 07-17-2017 | 08:22 PM
SB
BTW: a carb's boosters sprays fuel just over the throttle blades too.
SB is offline
Old 07-17-2017 | 08:48 PM
remove one of the top fuel bowl screws from each bowl and put a couple ounces of fuel in with a squirt bottle,push acc pump levers a couple times and reinstall bowl screws,hit key and start it up!
mike tkach is offline
Old 07-18-2017 | 12:07 PM
This turned out much simpler then I expected. Ihad forgotten I closed the fuel supply valve to the engine prior to removing the parts. Opened the valve, a shot of either and it's running fine.
ed
Old 07-18-2017 | 03:03 PM
Can you not prime the system by just pulling the the lanyard and cranking a few seconds? Won't it crank , but not fire???
buck35 is offline
