Prop suggestion? >
Prop suggestion?
Prop suggestion?
Old 07-17-2017 | 11:14 PM
Default Prop suggestion?
I'm currently running a stock Bravo 1 4 blade 28p prop. Boat is a velocity 280 with a 1.5 ratio bravo 1 outdrive. I'm currently getting 5200 rpm WOT and 73 mph with 2 ppl and 3/4 tank fuel. The engine is a fresh 496 stroker, 590hp. I'm considering stepping down to a 26p to utilize my rpm as I keep making power to 5600 rpm. Would a 26p bravo 4 blade be recommended? Or is there Better prop for this boat to get more top speed out of it? I'd like to find a good base prop and possibly have it labbed from there.
Blackedout02 is offline
Old 07-17-2017 | 11:30 PM
Most likely would be best to have your current prop labbed.
Your prop slip is on the high side at about 18% already so talk to BBlades about your options.
Griff is offline
Old 07-17-2017 | 11:36 PM
I guess I should mention that the 591 dyno number was not in marine dress.
Old 07-17-2017 | 11:38 PM
thats definitly my plan for the offseason. It's currently my only prop so I'd like to get a spare anyways, and figure a 26p might be a good choice? The 28p has the diffuser ring cut off, but gets on a plane effortlessly, and will even plane with 6-7 ppl on board and 3/4+ tank for fuel , definitly working, but it gets up
Old 07-21-2017 | 07:16 PM
I'd start with a 26 Bravo. The net 2" reduction in pitch will get a higher rpm more reliably than labbing a prop. I'm not against labbing but I'd start with a different prop in this case.
Trash is offline
Old 07-22-2017 | 09:09 PM
Being as it's a stroker and loads of torque down low, I'm curious if there's a different drop/# of blades I should try to give up some down low for top end
Old 07-22-2017 | 10:23 PM
I agree. I think the 26 Bravo would be a good prop.
Where are you located? Maybe you can borrow one to try.
underpsi68 is offline
Old 07-23-2017 | 09:45 AM
im up in Vancouver, BC. Unfortunately, there isn't much of a performance boating community up here
Old 08-08-2017 | 09:37 PM
Where in Vancouver I'm on Vancouver island with a 36' cig just working on some props from Ontario not much out here in B.C for sure.
Makin smoke is offline
Old 08-25-2017 | 11:13 AM
bbladesprops's Avatar
Offshoreonly Advertiser
My initial thought is to Lab the 28 with a efficient recipe.
However, a dyno sheet would clarify the decision.
Let us know if we can help.
Brett
[email protected]
bbladesprops is offline
