L@@king For A Bw Bellhousing And Spring Plate >
Old 10-14-2002 | 07:52 PM
TSNAVE
Default L@@king For A Bw Bellhousing And Spring Plate
ANYONE HAVE A SPRING-PLATE AND ALUMINUM BELLHOUSING FOR A 71 SERIES BORG WARNER TRANS?
Old 10-14-2002 | 09:06 PM
offshore score's Avatar
I think i do , I will check tuesday,
offshore score is offline
Old 10-14-2002 | 09:23 PM
Panther's Avatar
Frank's Marine Service
Default I have one
I have a bell housing and flex plate. The bell housing needs a little welding, since I cracked it in half, and the flex plate needs all new springs since that was broken too.
if you're handy with a welder, it's yours.
Just kidding!!!! Go check out Marine Power Services, they should have one. There was also a guy on OSO here in NJ who was selling TRS drives. He has bell housings, and flex plates.
Panther is offline
Old 10-15-2002 | 07:42 AM
CRUBOSS
i have two bell housings and drive plates. and flywheels. rear entry starter. all came off a cougar cat. with trs drives. all in great condition.
Old 10-15-2002 | 02:51 PM
TSNAVE
Thanks for the replies guys! My application is a little uncommon but here it is... The motor is in it's stock location when set up for a Bravo. I am adding an extension box and a 2-speed tranny in front of my Blackhawk. I'm certain that I need a bellhousing that will accomodate the starter in the standard "bolted to the block" location. Is it uncommon to use the starter in the stock location instead a rear mount with this type of bellhousing?
johnnyexcal
3
03-01-2008 09:46 PM
MILD THUNDER
11
10-18-2005 09:05 AM
ratman
12-10-2004 07:01 AM
azlineman
3
01-18-2004 11:18 PM
