Crack at the bottom of the transom is it fixable? >
Old 07-21-2017 | 02:02 PM
Default Crack at the bottom of the transom is it fixable?
Boat is a 1985 baja sport it comes with the 1990 mercury 150 xr4 black max with recently replaced lower unit. It has crack at the bottom of the transom, is this fixable and if so how would i go about doing it.
https://nh.craigslist.org/boa/d/baja...179403011.html
liftedchevy77 is offline
Old 07-21-2017 | 03:59 PM
Crack ?
HALLETT FAN is offline
Old 07-21-2017 | 05:01 PM
F-2 Speedy's Avatar
thats more than a crack, looks like a rotted lower transom and delamination of the bottom, that would be expensive to fix, but if you could pick it up for a grand pretty sure you could part it out and make money.
Edit: Im surprised it floats, there has to be water intrusion
F-2 Speedy is offline
Old 07-21-2017 | 05:07 PM
Let's put it this way. It is fixable. But the fact that you don't know how means YOU can't reasonably fix it. The motor and trailer look worth the asking price. It needs a whole transom before you worry about the major light leak at the bottom of the transom. One thiught: find a decent hull with no engine for cheap. Put the engine on that hull and then you can do long-term learning curve transom replacement. But if you try to slap some glass over that huge crack-hole you will watch that engine break right off the back of that boat-transom and all. Can you say "free swimming lessons?"
dereknkathy is offline
Old 07-21-2017 | 06:17 PM
That actually sounds like a very expensive swimming lesson.
Baja Rooster is offline
Old 07-21-2017 | 06:39 PM
Looks like it took a quick trip off the ez loader trailer onto the ramp.
buck35 is offline
Old 07-21-2017 | 06:59 PM
Did that once. First trailer I ever had that the rollers actually rolled.
Old 07-21-2017 | 08:47 PM
BUP
I would pass on that clunker even without the holes that you could put your hands thru
BUP is offline
Old 07-22-2017 | 02:15 PM
That boat is garbage. It would take an act of love to restore it. I would be suspect of the rest of equipment as well.
Old 07-23-2017 | 07:51 AM
spray foam and duct tape...
