Throttle return springs
Old 08-08-2017 | 08:33 PM
Default Throttle return springs
Anyone running throttle return springs?Been thinking about putting them on just in case you get tossed around they may help pull the throttles back some.
mod58 is offline
Old 08-08-2017 | 08:37 PM
Thether!
class6 is offline
Old 08-09-2017 | 10:01 AM
Yeah I have a tether also,just seeing if anyone is running them in conjunction with the tether .
mod58 is offline
Old 08-09-2017 | 10:05 AM
Do you want to hold the throttle ALL the time? If your just cruising the ability to leave it in a set position is pretty convenient .
phragle is offline
Old 08-09-2017 | 10:16 AM
This right here.
Buddy had them in his 36 Apache and they were more of a nuance than anything. Especially on casual boating days.
Nate5.0 is offline
Old 08-09-2017 | 10:18 AM
Knot 4 Me's Avatar
For hand throttles, I've never seen return springs used. For foot throttles I assume the unit itself has a return spring or they are hooped to where you use your foot as the throttle return.
Knot 4 Me is offline
Old 08-09-2017 | 11:57 AM
MrCIG's Avatar
Charter Member#330
I had them on my Cigarette. There was enough tension that if the cable broke they would return to idle. Not enough that you had to hold them all the time.
Mark
MrCIG is offline
Old 08-09-2017 | 06:47 PM
Thumbs up
Think I may give them a try for sh*ts & giggles,A buddy has 2 setups he runs on his dirt mod that I can try.
mod58 is offline
