525 cam install. sleeper motor >
Old 08-14-2017 | 06:35 PM
hammerdown500's Avatar
Default 525 cam install. sleeper motor
Need help
​​​​​​​. I have a buddy that wants to install.a.crane 525 efi cam into his 502 efi.
1. can it be installed.straight up or does it have to be degreed?
2. What base timing should it be set to?
​​​he is running a short runner intake and stock fuel system with pressure regulator at 41#
sleeper motor
hammerdown500 is offline
Old 08-14-2017 | 06:42 PM
With a 525 cam it won't be much of a sleeper. Those cams sound damn good
Crude Intentions is offline
Old 08-14-2017 | 07:20 PM
SB
Panther did a set just like that last year. Give'm a PM
SB is offline
Old 08-18-2017 | 08:55 AM
every cam should be degree checked .
mike tkach is offline
Old 08-18-2017 | 12:25 PM
Plus it needs an exhaust upgrade and valve train work to run that cam or engine will revert water and sleep with the fishes...
dereknkathy is offline
Old 08-19-2017 | 03:02 PM
So true. I've found cams to be off by 4*. Perhaps it was chain stretch, but you never know.
Baja Rooster is offline
Old 08-19-2017 | 03:26 PM
Is the built-in advance an attempt to compensate for chain stretch?
Old 08-19-2017 | 04:44 PM
Nope. It's built in assuming everything is as it should be.
Old 08-19-2017 | 05:30 PM
Always wondered. Since it seems they stretch quick and then stay that way a long time.
Old 09-03-2017 | 01:16 AM
Stainless or emi exhaust with stainless risers and 330cc heads
