502 Pro charger with closed cooling >
Old 08-31-2017 | 04:25 AM
Default 502 Pro charger with closed cooling
Hi,
i would like to know is there any restrictions to use closed cooling with pro charger setup? I have understand that many setups use crossover so I would like to know is there some restrictions for closed cooling (..like placement of water circ. pump or something like that)???
Does electrical circulation pump have enough flow for marine cooling?
oopee is offline
Old 08-31-2017 | 08:49 AM
procharged engines like to run very cold so no t-stat, you are going to have to tap in before the heat exchanger to flow water to intercooler, the engine pump should be fine
ezstriper is offline
Old 08-31-2017 | 08:02 PM
Maybe this will be of help?
http://www.offshoreonly.com/forums/d...iners-etc.html
Baja Rooster is offline
