bravo one conversion to a imco 2"shorty >
Old 09-10-2017 | 10:30 AM
Default bravo one conversion to a imco 2"shorty
Hello every I've been wanting to convert my bravo lower over to a Imco 2" shorty for quite some time now and finally got the financing to do it. I was wondering if anyone has done this before and can lead me down the right path. I have a 94 Bravo one 1.50 with a 1" prop shaft. Any help would be greatly appreciated.
I found a reman Shorty for 1700 or 3500 brand new. Just trying to see what it takes to swap them over.
Awainr76 is offline
Old 09-10-2017 | 04:57 PM
I think it is direct bolt in swap. I am gonna say it us. That way if I am wrong, somebody will call me stupid and tell us all what it entails...
dereknkathy is offline
Old 09-10-2017 | 05:03 PM
Easy swap. You may need to run a 4 blade prop. I did weld up and reconfigure the huge water inlet. Pressure was way too high and I was getting cav burn behind the inlet. I did a little blueprinting work on it also.
thirdchildhood is offline
Old 09-11-2017 | 01:29 PM
When I converted to -2's on my Fountain the water pressure went through the roof on both motors. The Imco opening picks up a lot more water. Had to install relief vales to bleed off excess.
Marginmn is offline
Old 09-11-2017 | 04:19 PM
When you converted yours was it was simple as sliding it on or did you have to change some bearings too? From what I see they give you everything so you can just take the old off (bravo one lower) and put on the new imco lower.
Awainr76 is offline
Old 09-11-2017 | 06:39 PM
Simple Swap, One wrench and refill with oil, Where a did you get a price for 3500 for new?
class6 is offline
Old 09-11-2017 | 07:05 PM
Awesome, I found a place called Dimarco marine online,Complete 1:50, 1" Prop Shaft .....................................$3,350Figured $3,500-3,750 with taxes and shipping
I still have to call them, but before I did I wanted to get a idea what I'm getting into.
Thanks for all the responses.
Awainr76 is offline
Old 09-11-2017 | 07:18 PM
what boat?
class6 is offline
Old 09-11-2017 | 07:45 PM
It's a 1988 Challenger, Blown 502 in it. Had a Boat builder buddy tell me I needed a 2" shorty to raise my x dimension and that should really help the boat run smoother.
Challenger was made in Cedar Springs, Mi in the late 80's early 90's
Awainr76 is offline
Old 09-12-2017 | 12:36 AM
The X dimension does not change. The propshaft height changes.
Griff is offline
