502 MPI Alarm System Questions?? >
Old 09-24-2017 | 12:18 PM
Default 502 MPI Alarm System Questions??
Bought 1999 Fountain with 502mpi mags. Livorsi gauges were installed and the alarm system was not hooked up so I have to constantly look at my gauges to make sure everything is okay. I noticed this after buying...
So my question is, does the alarm system for the high water temperature and low oil pressure read from the old stock gauges that had warning lights or does it read from the ECM?
I've done a search and cannot come to a conclusion. I'm new to these motors so I apologize if I'm sounding dumb.
jtbooten is offline
Old 09-24-2017 | 12:57 PM
It reads off separate sensors on the engine. It is not related to the guages at all.
Griff is offline
Old 09-24-2017 | 01:28 PM
Thanks. Next question is, is this one wire? What color would it be?
My my alarm lights and buzzer wires are cut. Can't find what use to connect them so I'll run a new one if I have to. My guess is that it was alarming all the time and they took the easy way out instead of fixing the problem.
jtbooten is offline
Old 09-24-2017 | 01:48 PM
F-2 Speedy's Avatar
this should help
F-2 Speedy is online now
Old 09-24-2017 | 03:56 PM
this should help
Thanks. I found that on google...16 would seem to be my answer but it goes to the ECM. Not sure where it goes to the dash.
jtbooten is offline
Old 09-25-2017 | 12:43 AM
Your previous guage warning lights were part of the guage. The warning lights go off based on the guage reading only.
The Merc alarm wires are usually Tan with a Blue stripe. The diagram above shows Tan with White stripe.
That is the engine harness above. It connects to dash harness via the 10 pin Cannon Plug.
Griff is offline
Old 09-25-2017 | 01:54 AM
That helps out a lot. In saying that, the Merc alarm wire monitors what? Drive oil only?
jtbooten is offline
Old 09-25-2017 | 06:36 AM
F-2 Speedy's Avatar
low oil pressure sender to the ECM ( most install where the oil pressure sender for the dash gauge is ) and drive oil level
Old 09-25-2017 | 03:25 PM
Low oil psi, high water temp, low drive lube
Griff is offline
Old 09-25-2017 | 03:47 PM
BUP
and general warning 2 -- if a transmission is in the mix.
also certain calibrations can set a horn --- 1 is soft alarm = 1 sec second on / 3 seconds off below 3000 rpms and a hard alarm = constant warning alarm above 3000 rpms when a active code is detected.
BUP is offline
