GM Techs: 2016 5.3 liter AFM issues >
Old 09-29-2017 | 08:58 AM
Default GM Techs: 2016 5.3 liter AFM issues
How wide spread is collapsed lifters? Do you see this regularly at your dealerships and what is the standard repair?
Truck is 13 months old, 26K miles and got a loud ticking in the motor yesterday. Noticed it at a drive thru and coincidentally was near a dealership (3/4 mile away). On the way there the truck had no power but no CEL's either. Service writer put me in a new 2018 Silverado and I was out the door in 45 minutes. Internet is full of horror stories but I just want to know how common is the issue is and is the fix a permanent solution or just a band aid until the warranty runs out! Anything specific I should look for or ask about?
Note the 2016's have a shorter powertrain warranty also (60K miles vs. the former 100K).
Jupiter Sunsation is offline
Old 09-29-2017 | 09:27 AM
AFM has been hard on the special lifters for a while now, they did release a updated lifter a while back but I would think yours would have that, not changing the oil(don't go by oil life display) and the cycling of the AFM ib and outare biggest reasons to fail I'm told. I have a 5.3 and a 6.2(which killed a lifter) but I used superchips tuner and turned the AFM off(saw no loss in MPG) Not sure why yours failed that soon, have not heard of many low mileage failures.
ezstriper is offline
Old 09-29-2017 | 01:34 PM
Lifters are out and seem fine. They are now looking at a collapsed piston?!?!
Old 09-30-2017 | 09:40 AM
AFM is much better than it used to be. There is no such thing as a Collapsed piston. You would have a bad wrist pin bearing or a bad piston.....
wannabe is offline
Old 09-30-2017 | 10:08 AM
More likely a bad cam lube than a lifter,,but we also have had a few with piston slap that sounds like a lifter tick,,,
​​​​​older ones were common for lifters sticking,,not so much one the newer ones
boatnt is offline
Old 09-30-2017 | 01:38 PM
Collapsed piston was the service writer's exact words........notice I put ?!?!?! after it when I typed it above as it didn't make sense to me either. No smoke, no CEL just a loud ticking and no HP when you pushed the pedal.
Old 10-04-2017 | 05:32 PM
Truck is done.....
Service writer was confused at best. I talked with the guy who did the work instead:
#4 lifter collapsed (google search called it correct as that is an issue on the 5.3)
Replaced all lifters (both on both sides), inspected pistons/wrist pins
Pulled oil pan, replaced oil pump, new oil/filter.
Mechanic said he hadn't seen one fail with so little miles (26K).
So now the question is, just pound miles on it or trade it before the warranty expires?
Old 10-04-2017 | 05:47 PM
I am spoiled by an awesome F250 Super Duty which is a beast, but regardless, I would immediately dispose of any vehicle that required internal engine work in the first 26k miles. But that's just me, I want a lot more reliability for my money. Imagine what lies ahead at 50k, 75k, 100k.
Thunderous is offline
Old 10-04-2017 | 05:50 PM
I agree......I have never had a vehicle that needed any type of internal engine work even with 100-150K miles on them. GM also cut the powertrain warranty from 100K to 60K starting in 2016. Service writer estimated this was a 5K job..... I asked: 5K for just changing lifters? He back peddled a bit and basically said he wasn't sure what it would cost.
Old 10-04-2017 | 10:52 PM
I'd also be a little worried that they just stuck 16 more of the same sh!tty lifters back in my truck like the one that failed. I didn't know GM cut the warranty back on their trucks....that's surprising.
