New problem with head >
Old 10-02-2017 | 04:48 PM
Default New problem with head
Just had these heads completely gone through. New guides ,seats and decked .on my last ride a rocker arm popped off the pushrod on the exhuast. Look what i found REALLY
veloc410 is offline
Old 10-02-2017 | 04:57 PM
That is the exhaust port and valve stem on 2 different ports
veloc410 is offline
Old 10-03-2017 | 09:02 AM
I'm pretty sure I know what happen let's see if anybody can come up with the same conclusion I do before I take The heads apart..i can think of 3 things that went wrong on installation
veloc410 is offline
Old 10-06-2017 | 08:21 AM
I have no clue but you are having some serious ****ty luck. I sure hope next summer is better for both of us.
cabin fever is offline
Old 10-06-2017 | 08:33 AM
#1 The outer diameter of the valve guide bushing get shaved by the hole when it was pressed in. Removing some material needed for a proper press fit #2 They should be using loctite in the hole when they press it in #3 The guide bushing got cracked while it was pressing in. After a few heat cycles the crack shifted, it acted like a collet it and grabbed the valve stem holding it open long enough for the rocker arm to come off of the push rod. I don't think there's any major damage done because the valve looks OK looking at it from the exhaust port it may be bent but nothing serious . Point is I still had to take my engine out of a dam boat I'm pissed off . Poor worksmanship. How do I trust that place again. I'm sure they will fix it for free but who wants to have the same issue again I'm still wondering if I'm going to have any problems with my other guides .
veloc410 is offline
Old 10-06-2017 | 08:41 AM
To old for this
veloc410 is offline
Old 10-06-2017 | 08:47 AM
By the way a man lift works nice for taking the engines out. I took the other engine out because oil pressure is to high and want to change the spring. I'm also looking at drilling rear of heads to return oil back to pan directly from heads
veloc410 is offline
I feel your pain brother. I still go "nervous" boating.
Everytime i was seriously ready to give up i remebered what my grandfather taught me....."challenges builds Character". Hang in there man , you'll get it
Wish u were closer, id give ya hand.
Old 10-06-2017 | 08:58 AM
👍👍👊 thanks they are in the garage now so I have plenty of time to fart around with them. I haven't driven my my hotrod all summer. It needs rear tires and inspection. Think I'm going for that first.
veloc410 is offline
Old 10-06-2017 | 09:05 AM
Left her on the back burner to long because I love the water so much.
veloc410 is offline
