Sealant
Old 10-07-2017 | 09:38 AM
Default Sealant
While the engines were out for maintenance I am replacing the indicator cables to the outdrives. What is the sealant used under the covers where the cables go thru the stern? Its black if that helps. Thanks
fordf350 is offline
Old 10-10-2017 | 03:04 PM
black 4200
Pismo10 is offline
Old 10-11-2017 | 01:07 AM
Its probably just marine grade black silicone sealant.
Griff is offline
Old 10-11-2017 | 02:15 AM
Indicator cables? The wires going thru transom assy? They also are in a rubber grommet. I would look into getting a new one of those. It is barely above the waterline. Also, you need wire that can handle that environment. It looks like a cord off a lamp, but it is not...
dereknkathy is offline
Old 10-11-2017 | 12:45 PM
He's talking about mechanical trim indicator cables with the clam shell cover.
Griff is offline
Old 10-12-2017 | 01:35 PM
Then they are well above waterline and whichever permanent sillycone closest matches the hull color.
