36 Baja Outlaw 500 EFIs builds >
Old 10-13-2017 | 06:50 AM
Default 36 Baja Outlaw 500 EFIs builds
SO I have a 36 Baja with twin 500 EFI blue motors that at are at the end of there life cycle at 520 hrs. Both motors still run great other then both have a minor oil leak at the rear seals or pan gaskets. I am pulling both engines out of the boat and going to go through both of them. My question is should I go back to stock with the builds and just upgrade the cams to a 525 cam, or should I do stroke kits and make them both 540s. My fear is the heads and intakes are not going to flow enough to make the boat faster and Im not sure its worth the extra money. I already know I need to change out the throttle body's if I did go to 540 builds. I am also on a budget, and I am going to do most of the work my self except machine work. boat runs 72 MPH right now on GPS. I would like to see 75 or 78 after I'm done. 80 MPH is probably wishful thinking. The boat is equipped with bravo one drives just in case anyone wants that peace of the pie as well. Thank you guys for any help.
Lou.Slater is offline
Old 10-13-2017 | 07:10 AM
540's will suck up a bunch of cash to do them right, don't go there if you're on a budget, to pick up 6-8 mph will be expensive with that hull,
Thank you for your reply
Old 10-13-2017 | 07:52 AM
It's going to depend on what you find when you open them up.
if everything's good or needs minor work.Then leave them stock and just change the normal wear items.But if you get into them and need a new crank along with cylinders bored then it might be worth the difference in price it to go to a 540.
Warship2k15 is offline
Old 10-13-2017 | 07:57 AM
Thank you
Old 10-13-2017 | 08:17 AM
You budget is the factor. The 540's will get you the performance you want even with the throttle valve and heads you have and if you upgrade those I believe you'll see even a bit more speed also keep in mind that tune needs to be checked on a Dyno with good data collection such as fuel flow exhaust temps and O2 readings before you put them back in the boat it may take something as simple as a bit more fuel press or a bit more complicated and you may need to retune the ecu. Which you should probably do even if you do a cam swap only as well. Best of luck keep us posted . Laz
MESABALANCING is offline
Old 10-13-2017 | 08:42 AM
Thank you for your input.
Old 10-13-2017 | 08:46 AM
F-2 Speedy's Avatar
where do you boat, what shop is doing the machining and heads
F-2 Speedy is offline
Old 10-13-2017 | 09:01 AM
Not sure what machine shop I'm using. I live in Lansing mi, so I go to lake Michigan and lake st Clair.
Old 10-13-2017 | 09:03 AM
Thank you for your input, I planed on dyno time no matter what way I go. I don't like just a down load that someone else came up with even though it worked on other engines. I believe that every engine are different from each other and they should be dynoed to get the best performance and programming for each engine. Thank you
Old 10-13-2017 | 09:05 AM
F-2 Speedy's Avatar
Smitty ( Articfriends ) on this board is up in your area and can tune the MEFI's on his dyno
