42 drive heights
Getting ready to cut out my 98 42 big step for #6s. It was glassed up and set up to be a stagger. What should the prop shaft height be and what should the center to center be on drive spacing. Thanks for the input🙂
You'll probably want to go with a 5 blade prop with that much power . The bottom of the assembly is up 6" from the bottom on the 850 boat I measured . Have always been told 1" above the bottom for pleasure use .I am trying to find some five blade 39 or 40's to try on mine . Running 38 6 blade now
