head gasket selection >
Old 11-06-2017 | 06:34 AM
BBYSTWY's Avatar
Default head gasket selection
need help choosing head gaskets...in the process of "freshening up" my 525 sc....its getting a set of dart heads roller cam and 575 sci blower...whats a good choice for head gaskets?? it will have ARP head studs installed as well...may seem like a dumb question but I know not all gaskets are created equal
thanks
Stewart
BBYSTWY is offline
Old 11-06-2017 | 06:54 AM
Need to know more about the setup to recommend an exact head gasket.... desired compression ratio, piston cc, head cc, etc.
I would highly recommend an MLS (multi-layered steel) head gasket though, but I cant make a recommendation on brand or thickness
TorchLK is offline
Old 11-06-2017 | 07:14 AM
BBYSTWY's Avatar
oh yea sorry...shooting for 8:5:1 forged pistons not sure on brand yet....119 cc dart heads iron eagle that's about all I know at this point...looking for 7-8 lbs of boost and it does have a chiller
thanks
Stewart
BBYSTWY is offline
Old 11-06-2017 | 08:27 AM
you don,t need a mls gasket for you,r power leval,a fel pro perma torque would be what i would use.edit in,i also would not use head studs,arp head bolts would be a better choice.
mike tkach is offline
Old 11-06-2017 | 08:30 AM
BBYSTWY's Avatar
would the MLS be added protection?? just want to make sure hopefully I only do this once hahaha
thanks
Stewart
BBYSTWY is offline
Old 11-06-2017 | 10:22 AM
dcb
thanks
Stewart
You need to have heads and block machined to a finer RA for MLS gaskets.
dcb is offline
Old 11-06-2017 | 10:40 AM
BBYSTWY's Avatar
so maybe just stick with the felpros and hope for the best??
What about this...lets say the engine had 9:1 compression...how does that change things??
Stewart
BBYSTWY is offline
Old 11-06-2017 | 12:27 PM
The Felpro marine gaskets will be fine. I ran them on my bumped up 525SC with 8# of boost.
Griff is offline
Old 11-06-2017 | 01:16 PM
I'm sure a stock style head gasket will work just fine but I would highly recommend stepping it up to an MLS. Especially since you are re-doing everything you can have the heads and block finished to the correct surface finish for an MLS.
I cant think of any drawbacks to an MLS if done properly. I cant actually name a modern engine that doesn't have an MLS gasket.
Also, what is your reasoning for recommending head bolts over studs?
TorchLK is offline
Old 11-06-2017 | 02:17 PM
I also just used ARP head bolts and not studs on mine.
IMO, studs are overkill for what he is doing and he will most likely have to grind the lower studs to clear the exhaust.
Griff is offline
