1989!Baja 226 won't plane out! >
Old 11-22-2017 | 12:35 PM
Default 1989!Baja 226 won't plane out!
Bought this 1989 baja 226 sport this last May 2017 and have had problems since.. won't plane out with more then myself in it unless people sit in cubby, real nice shape interior wise and runs great, 500 hours on motor, 21 stainless 3 blade prop, does NOT have trim tabs, new into the baja world and getting frustrated, its trimmed down as far it can go.. could the styrofoam be waterlogged? Any other thoughts?? Boat sat for a 2-3 years before I got it, had to go through whole fuel system... Not wanting to tear up the whole floor and inside of the boat and unravel more headaches.. any feedback is great thank you!
Joepaakk is offline
Old 11-22-2017 | 12:38 PM
What power? Verify prop. Have you done a compression check? Tune up? Verified timing?
Crude Intentions is offline
Old 11-22-2017 | 02:15 PM
I have not done a tune up or compression test, boat does 55 mph once on plane, I figured if it had low compression it wouldn't run well, just trying to brainstorm for spring time when it comes outa storage
Joepaakk is offline
Old 11-22-2017 | 02:16 PM
Boat has a 454 magnum
Joepaakk is offline
Old 11-22-2017 | 02:29 PM
That should have no problem turning a 21. I'd start with the simple stuff and tune up check compression. That thing should pop out of the water with a big block and a 21.
Old 11-22-2017 | 02:31 PM
Definitely have to in the spring thanks for the advice !
Joepaakk is offline
Old 11-22-2017 | 02:38 PM
Also verify your drive is trimming all the way in. Don't just go by a gauge. That would make a huge difference too
Old 11-22-2017 | 03:36 PM
dcb
Dont forget to check the celery stick on the drive trim rams - if backwards will prevent drive from trimming all the way down.
dcb is offline
Old 11-22-2017 | 03:41 PM
How many rpm's you turning at WOT with just you?
AllDodge is offline
Old 11-22-2017 | 04:12 PM
A 454 mag should launch that thing like a surfboard.
Baja Rooster is offline
