sbc: comp cams xe262 reversion risk? >
Old 12-22-2017 | 02:28 PM
Default sbc: comp cams xe262 reversion risk?
HI, building mild 350 with pocket ported 997 heads, 9:1 comp, edl air gab, glm exhaust manifolds. is there any reversion risk with comp xe262 cam?
JaniH is offline
Old 12-22-2017 | 04:14 PM
You would be okay with the XM262H, the additional advance and the 2 degrees less lobe separation with the XE version is probably a deal breaker though. Open thru hull exhaust or thru-prop? I ran the XM262 in a similar setup with 882 heads but stroked to 383. I had 9.6:1 comp. and it was too much. I was trying to use the flat tops that I had, but should have changed them out. Very torquey cam, would probably run out to about 5200-5300 with a 350.
94sylvan is offline
Old 12-22-2017 | 06:07 PM
GPM
The power range seems well suited for a boat. XE262H-10, Camshaft Part#12-238-2 Dyno Sheet
GPM is offline
Old 12-22-2017 | 07:19 PM
I'm not keen on the 110 LSA. Look at some of the Crower Hyd roller models.
Trash is offline
Old 12-23-2017 | 12:06 AM
Is the 110lsa realy too tight in this mild cam. Allreaydy have this xe262 & edellbrock performer cam. Performer is with 112lsa, but is not enough cam to my goals.
JaniH is offline
Old 12-23-2017 | 12:40 AM
Comp xm262h. Exhaust closing 19 deg atdc. Intake opening 21 deg btdc. Overlab 40deg.
Comp xe262h. Exhaust closing 21 deg atdc. Intake opening 25 deg btdc. Overlab 46 deg.
2 degrees diff in exhaust closing point betveen These cams.
JaniH is offline
Old 12-23-2017 | 01:00 AM
Silent choice, so both options.
JaniH is offline
Old 12-23-2017 | 09:46 AM
I ran the XM262H with stock center rise exhaust. Never had an issue.
79formula is offline
Old 12-23-2017 | 10:06 AM
Yes, with the lazy ramps of a flat tappet grind and stock exhaust this cam has a lot of duration for such a "mild cam" when used with stock exhaust. I would go with the xm grind. You will like it.
94sylvan is offline
