Black hull side, maintanance nightmare? >
Old 12-27-2017 | 06:46 AM
Default Black hull side, maintanance nightmare?
I am in the market for a 23-24 CC for cursing and some nearshore fishing. I Found a decent deal on a used boat (seahunt, triton 24) but it has black hull sides from run rail down. It clean and polished but since it will be used 100% in Florida sun I worry the black will require more waxing and maintenance then I am used to. (Always had boats white with accents only). I am use it more than polish on the weekend type guy and put about 200hrs a year on a boat. Anyone ever have a dark color boat, any thoughts?
happy hours is offline
Old 12-27-2017 | 09:32 AM
Unless the boat is kept out of the sun and overly maintained the red, blue and black hulls all look sorta chalky by seasons ends. The white hulls are the same but the oxidation doesn't show as much.
Interceptor is offline
Old 12-27-2017 | 10:32 AM
Mine is a 292 formula and the black is Imron, not gell. It is very easy to keep up with. It just needs to be wiped down after every use with a spray wax.
COOPS is offline
Old 12-27-2017 | 04:42 PM
Too Stroked's Avatar
Black is an absolute maintenance nightmare - and even worse if you're in Florida. If the color is in the gelcoat, it will generally oxidize within a year or two - even if you keep after it. If the color is done in paint, it'll last a bit longer. And that's not even mentioning the somewhat more manageable issues of hard or salt water stains that will show like crazy. I'd be willing to bet that if the boat you looked at is used, it was carefully buffed out by the dealer already. And remember, once gelcoat has oxidized, you'll be buffing it constantly just to keep it looking acceptable. On the plus side, your boat will weigh less every year though!
Too Stroked is offline
Old 12-27-2017 | 06:45 PM
Back around 1990 we owned an early 80’s Baja that was all black- at 10 plus years old the topside and deck were a SOB but the sides were pretty easy to keep up. I see a lot of black and navy sided Cobault, Formula, and Proline running around the Tampa Bay Area that look good.
Powerquest230 is offline
Old 12-27-2017 | 07:25 PM
rak rua's Avatar
My 34 Fountain had black hullsides. Never had a problem BUT it was lightly used and kept indoors.
Keep one indoors I'd think no problems. If it sits outside, lots of polish!
RR
rak rua is offline
Old 12-27-2017 | 08:36 PM
Be sure to buy a black Sharpie marker to keep on the boat also.
wananewboat is offline
Old 12-27-2017 | 09:29 PM
last three boats have been all black. started with black gel, then custom painted black with flames. never had a issue with mine, and would do it again.
beertruck is offline
Old 12-28-2017 | 07:23 AM
seafordguy's Avatar
If my red SeaDoo is any indicator I would look for another boat. That thing can fade under a cover.
seafordguy is offline
Old 12-28-2017 | 07:36 AM
My Hydrostream was black and you could literally fry eggs on it even in Michigan sun! Seats were gray and I had to cool them with water before sitting on them. No good!
thirdchildhood is offline
