Merc 280 K-Planes >
Merc 280 K-Planes
Merc 280 K-Planes
Old 01-02-2018 | 08:46 AM
Veteran: Navy
Default Merc 280 K-Planes
The dimensions of the 280 as per web diagram is;
Wide- 14"
Length- 19.25'
Tip- 9"
What I need to know is the length from the transom to the point where the inside angle starts, that goes to the tip. Another words, the length from the transom to the point of intersecting lines.
This way I can make a template and see if the planes will fit without interference.
Thank you very much for your time.
David..........
AmiableDave is offline
Old 01-02-2018 | 11:57 AM
I'll measure mine when I ger home tonight if no one responds by than.
underpsi68 is offline
Old 01-02-2018 | 12:07 PM
Just checked.........6" off the transom.
Griff is offline
Old 01-02-2018 | 12:49 PM
Veteran: Navy
Griff, 6" of the transom, At that point the angle begins that goes to the Tip. Is that correct?
Thank you for your time......Happy New Year.
UNDERPSI68...Thank you for getting back..
Old 01-02-2018 | 09:12 PM
BUP
If I understand your question - would nt transom width play into your question as well - inwhich you need to be asking another exact same boat owner as yours . Maybe I am over looking your question from post 1 and totally miss what exactly you are asking.
Your 292 has twin engines correct ? and how are you mounting the tabs ? following the transom line or mounting them straight across horizontal ?
BUP is offline
Old 01-03-2018 | 12:32 AM
Yes, the plates start narrowing at an angle 6" from the transom.
Griff is offline
Old 01-03-2018 | 07:27 AM
Veteran: Navy
BUP
If I understand your question - would nt transom width play into your question as well - in which you need to be asking another exact same boat owner as yours .
I did ask with ZERO results. I did however have 44 members read my question. Possibly waiting for my results so they can change out theirs.............
Yes.............
I'm going to follow the boats bottom transom deadrise angle.
Griff, Thank you again... Ask twice, cut once.............
Old 01-03-2018 | 07:47 AM
Knot 4 Me's Avatar
Results: 292 with 280S K-Planes
Knot 4 Me is offline
Old 01-03-2018 | 07:50 AM
Knot 4 Me's Avatar
And in case you don't see the link in the link above...
Got the K-Planes on my 292...
Old 01-03-2018 | 10:06 AM
Veteran: Navy
Thank you Knot 4 Me
