87 Top Gun hatch ram pictures? >
Old 01-28-2018 | 07:08 AM
Full Force's Avatar
Default 87 Top Gun hatch ram pictures?
Trying to find out if this pivot point is factory, seems like it since there are no other holes, and the boat has not been messed with, my issue is the hatch don’t open very high, but I am finding the cylinder is lower then all the others I see pics of, thinking that’s my issue, guys say it’s because no slider but either way the arm only raises so far slider or not...
tryinf tobsee what other early guns had?? Mines 1987
Attached Thumbnails 87 Top Gun hatch ram pictures?-9a6b26d9-f7d5-46f3-b27e-bb8798b1f269.jpeg   87 Top Gun hatch ram pictures?-031c05cf-b7ce-4946-b6c7-c4af0432eaab.jpeg   87 Top Gun hatch ram pictures?-0c35ad6c-90c0-4d77-8011-4315db5b0a12.jpeg
Full Force is offline
Old 01-28-2018 | 09:17 AM
Rhythm and Blues's Avatar
Tim, I forget if someone asked on FB but out of curiosity what happens if you change the pivot point to the hole further aft? I know this is kind of deviating from your question slightly bit I was just wondering..
Rhythm and Blues is offline
Old 01-28-2018 | 10:07 AM
Full Force's Avatar
Puts too much pressure on the arm then, I drilled the hole back there to try it... stresses out the hinges , seems the cylinder needs raised more
Old 01-28-2018 | 10:25 AM
gotcha, or a cylinder w more throw?
Old 01-28-2018 | 10:30 AM
J-Bonz's Avatar
Yeah, I gotta agree with the no slider comment.
J-Bonz is offline
Old 01-29-2018 | 07:34 AM
Tim, I just found my old arm with a slider if you want it. You would need to make the channel with the slot (or I can have it cut on a tube laser). Let me know, it's sitting in my office taking up space and I'll eventually just throw it out.
frickstyle is offline
Old 01-29-2018 | 08:08 AM
Full Force's Avatar
Can you bring it home? I have the slide part on the spare hatch in barn...!!
Old 01-29-2018 | 09:50 AM
J-Bonz's Avatar
Winner winner.....
J-Bonz is offline
Old 01-29-2018 | 09:52 AM
Full Force's Avatar
I know for a fact the arm isn’t my issue but his is set up for roller, the biggest issue is my cylinder mounted lower then others... looking to raise that also
Old 01-29-2018 | 10:29 AM
Is the arm (being "hard" mounted like that), limiting the range of motion of the cylinder? "binding" it???
With the roller, you have more range of motion to take advantage of the mechanical advantage with the ram/arm/whatever linkage.
Is the cylinder fully extending? What does it look like tied to the stringer? Mine is stock,we could measure mine fully extended, and fully retracted.
